flywheel bolt 12mm triple square? confirm pls!
1998 2.8Q
replacing clutch can someone pls confirm bolts for flywheel are 12mm triple square? thanks ted |
No. They're a 12 pt bolt, about 17mm as I recall. You don't need a special tool, just a 12 pt socket. And you aren't supposed to reuse them, as they're a stretch bolt. You tighten to the torque spec, then add another 180 degrees.
Sorry shredr, I was thinking today I was wrong. The ones I described fasten the flex plate to the crank on the auto. The clutch ones look like this:
http://www.ecstuning.com/Audi-B5_A4-..._Bolts/ES2152/ |
Originally Posted by mtroxel
(Post 24175898)
http://www.ecstuning.com/Audi-B5_A4-..._Bolts/ES2152/ http://c1552172.r72.cf0.rackcdn.com/9384_x600.jpg yes that should be a 12mm triple sqaure tool you will need. |
