Fml Audi gang probs
Fml Audi gang probs
Where hell gets worse
Egr sai pump delete. Upper head coolant pipe aka t pipe aka the crackhead baby design. Well the o rings failed in the flanges that attach to the heads. Needles to say in tearing down the motor found a bunch of other **** ton problems
1 passenger side sai valve or combi valve filled jam packed full gunk bo breathing through it like a bitch getting assaulted for the first time.
2 driver side I guess egr valve idk filled with water like a bitch just squirted all over the place bit wasn't warm
3 o ring failure causing in t pipe pissing eurofreeze all over the 02 sensor, **** melted down along with the temp sensor connector along with the purge valve or whatever vaccume bs sits on top of the throttle bod.
4 whole valley pan was ****ed jam packed full of dinkleberris no gasket.
5 o didnt even get in to the breathing tube on intake manifold
6 couple clips on the fire wall strait broke or melted away or something cause they ****ing gone
Popped 15 codes when I obd11 checked it sweet lil dude fr
7whole sai tubing filled with water.
8 whole sai pump filled water.along with the clip
Any one got the resistor to plug in where the sai pump did and also a piggy back?
jlag
Audi 100 / A6 (C4 Platform)
09-21-2005 05:33 PM
