Found Oil Around Spark PLUGS ???
While checking the spark plugs on a Audi A4 B5 1999 1.8 20V petrol i found oil around the holes of the spark plugs is that a problem or should i lokk further into it any help thanks???
Leaking valve cover gaskets. Very common, DD.
From experience, the leakage is often caused by overpressure under the valve covers and this is related to clogged breather tubes. The culprit is often the valve referred to as a suction pump. It's a cheap ($14) part that should be replaced when you do the valve cover and cam gaskets. There are myriad writeups regarding this service on the site.
Str8crusin
Q7 MK 1 Discussion
11-07-2018 06:21 AM
Onebad S4
10-14-2007 05:41 AM
Jargen
03-26-2007 11:28 AM
pac1085
02-25-2007 08:36 AM
