Headgaskets?
Old May 30, 2007 | 08:07 AM
Boosted_4cyl's Avatar
New Member
Default Headgaskets?
I have a 1998 30v and have been having an overheating problem. There has been no extreme pressure on any of the hoses. The temp gauge will go up to the center, stay there for a couple min and then go all the way to "H" and the light will go on. I just opened the air bleed on the upper rad hose (right near the coil packs) and nothing but steam came out. Although I did not see any bubbles going to the tank. Fans are working fine, it runs perfect.
Just need somebody to confirm that the problem would be the headgaskets.
If so, is the headgasket job a bitch? What it the toughest part?
Thanks a lot for any help.
Old May 30, 2007 | 08:13 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default How about a bad temp gauge sender? I doubt you can find anyone here that has...
...experienced head gasket issues on the 30v.
Old May 30, 2007 | 08:16 AM
New Member
I was thinking that too until i bled all the air out of the system
Old May 30, 2007 | 08:56 AM
n0yxl's Avatar
Default Throw a thermostat at it 1st.
Could be a number of things, t-stat being the cheapest; i'd try that 1st.
Old May 30, 2007 | 08:59 AM
New Member
is the thermostat under the intake manifold?
Old May 30, 2007 | 10:22 AM
Justin517's Avatar
Default on a V6? lol... might as well do a timing belt if ur close to the time to do so...
its in front under the covers.
Old May 30, 2007 | 12:36 PM
OA 69's Avatar
Default .... directly above tensioning pulley
<ul><li><a href="http://www.12v.org/engine/index.php?section=cl&amp;view=tbelt">click !</a></li></ul>
mike sanchez
Jan 2, 2018 10:16 AM
Newzshooter
Feb 23, 2011 07:36 AM
sgt.meowenstein
22
Jan 14, 2009 08:20 AM
CF4L
May 11, 2008 09:13 AM
meister
Dec 23, 2004 05:34 PM
