Heater problem only gets hot when revving engine?
Re: Either a lazy pump, or air in the system...
could you please explain in detail i would appreciate it. I just had the coolant changed with timing belt and we bled the air out it did seem hotter after that but still not hot. will changing the ect have anything to do with this?
thanks
thanks
Changing the ECT should not have anything to do with how much heat it makes...
did they bleed it and get heat at the dash? I'd try to burp it again.. get it good and hot, then CAREFULLY open the tank cap.. that will force (hopefully) the air out of the system.
Re: Changing the ECT should not have anything to do with how much heat it makes...
Just tried bleeding the system with car warmed up I opened the coolant cap slowley and air did escape, but the system is still blowing cool air not hot?
what else can I try I am stumped!
tarpeyphoto
02-21-2014 05:31 AM
