Help with ABS Sensor
Old Jan 30, 2009 | 10:33 AM
Mark1.8T's Avatar
Junior Member
Default Help with ABS Sensor
STFA and found that a potential cause for my brakes to pulsate while stopping is a dirty ABS sensor. Been searching the archives to see where the ABS Sensor is located exactly, but the post I found is old and the pics are red x's.
Does anyone have a picture? Is this a relatively easy DIY?
I have a 1999.5 A4 1.8T quattro with 84,000 miles (I know, I don't drive much). The ABS light is not On. Just today, everytime I step on the brake pedal, it slowly pulsates back against my foot. As the car slows, the pulsating slows.
Any other causes? Warped rotors?
Thanks for any help.<ul><li><a href="https://forums.audiworld.com/a4/msgs/2133484.phtml">https://forums.audiworld.com/a4/msgs/2133484.phtml</a</li></ul>
Old Jan 30, 2009 | 10:58 AM
DaveInSaltLake's Avatar
Default follow the wire....
seriously, it's at the end of one of the wires that run to your wheel hub.
the front wheel will have 2 wires: brake pad wear sensor and the ABS sensor.
rear wheels just have a wire to the ABS sensor.
hope you're savvy enough not to confuse it with the brake hydraulic line or the parking brake cable.
rotate the sensor GETNLY with a pair of channel lock pliers while pulling it out. If you're lucky you'll get it out without destroying it. sometimes they get rusted in there pretty badly.
when you get it out, spray carb cleaner and compressed air down the hole while you roate the hub. clean off the sensor itself, too.
Old Jan 30, 2009 | 11:45 AM
Mark1.8T's Avatar
Junior Member
Default Thanks, will give it a try.
If I do destroy the sensor, can I still drive the car? It's my daily driver.
Old Jan 30, 2009 | 12:21 PM
Default yes.
your ABS light will turn on and that system will be inactive.
Old Jan 30, 2009 | 12:24 PM
Default so describe more fully the pulsations you're feeling...
You'd feel the ABS pump pulses at a rate of 4 or 4 per second...or more, and it wouldn't vary with speed.
I'd want to look closely at the bolts holding the brake calipers on the hub, the lug nuts, and front suspension parts before messing with the ABS sensors.
Old Feb 1, 2009 | 05:21 PM
Mark1.8T's Avatar
Junior Member
Default Re: so describe more fully the pulsations you're feeling...
No, the brake pedal does not pulsate like when the ABS activates normally. The pulsating varies with speed, going at 25 MPH would pulsate almost 2 per second, as the car slows, the pulsating slows to about one per second around 5 to 10 MPH until stop. So the car does not slow smoothly. And it sounds like the pads are worn down but when I look at the pads, they look fine.
Just today, I noticed the brake pedal was stiffer just after I started up the car. Also, I'm hearing a sound, almost like metal scraping or brushing up against something but in pulses, again varying with speed.
Appreciate the help, what are your thoughts? Sounds like it's time to visit the shop.
501D22G
Feb 15, 2012 05:07 PM
whodeyrob
May 4, 2009 12:15 PM
iCar
Dec 12, 2008 04:58 PM
onyekachi
May 25, 2005 01:53 PM
jif
Audi 100 / A6 (C4 Platform)
May 26, 2003 10:11 PM
