Help....boost issues
Old Mar 28, 2001 | 09:04 AM
audi/s/scott's Avatar
Default Help....boost issues
Anyone know how to locate an air leak in the turbo system on a 1.8t? I've looked and listened but I can't find anything. The problem is when chipped I can't get past 12lbs of boost. I used to get 15-16. With the stock ECU things perform normal so it's not a wastegate or turbo problem. Any suggestions on how to find the leak or a local *experienced* shop that could, around Hartford.
Thanks
Old Mar 28, 2001 | 09:09 AM
WYSIWYG's Avatar
just to share, my first boostgauge install had a very audible leak but still took me past 15psi
Old Mar 28, 2001 | 09:21 AM
audimods's Avatar
Default you can take it in or check yourself, try taking one end of the vacuum line and
pressurize it with a bike pump or something. maybe you can detect the leak that way when everything else is quiet. just a thought, not sure if i will be detectable in your case.
Old Mar 28, 2001 | 04:20 PM
CMH's Avatar
CMH
Senior Member
Default Are you sure it is not the Bailey BPV that you are using.
Becaause after awhile the spring inside might get soft.
complacentsee
Oct 7, 2009 08:38 AM
noSup4u
Oct 19, 2006 05:10 AM
The_Jerbel (Jordan)
Oct 10, 2006 05:12 PM
dano-oly
Aug 23, 2005 09:30 PM
Quattrokai
Pacific Northwest Discussion
Oct 27, 2004 02:30 PM
