Help with a cooling problem...
Car is a 2000 B5 A4, TQM, ATW. Today was suddenly cold in our area, and I now have a fairly serious coolant leak- I'd appreciate any suggestions in narrowing it down. Symptoms are no heat, though the temp gauge reads operating temperature, medium amounts of steam from under the hood. Source of steam is pretty far down, definitely on the back of the engine, probably slightly on the passenger side but hard to tell exactly where. Coolant is definitely circulating, probably just not reaching the heater core. After 5-7 minutes of driving, the coolant light comes on. Since this has just one head, I'm thinking it might be some big cooling hose that's off-center somewhere in the back of the engine. Are there any common/likely points of failure I should look at first? I've done mostly stuff in the front- never ventured to the dark unknown behind.
Let me know how best to find and fix this.
Thanks!
