Help Diagnosing Problem Please - Steering Problem
Old Feb 25, 2009 | 12:22 PM
SolidFish's Avatar
Junior Member
Default Help Diagnosing Problem Please - Steering Problem
This is from a 2001 A4, 78k, on Koni for most of its life.
Since last year, I've been getting a moderate amount of noise when steering at low speeds, ex. during parking. You can hear almost a creaking sound from the front. I'm pretty sure its not from the steering column. The noise doesnt sound good, almost as if a bar is about to snap or something. I'm thinking its a bad boot or joint.
I'll have it on the lift this weekend. Any suggestions on what I should look for specifically?
Thanks
Old Feb 25, 2009 | 12:31 PM
jprice@CPS's Avatar
Member
Check control arms and tie rod ends.
Old Feb 25, 2009 | 02:11 PM
audiTLC's Avatar
control arm bushings cracked, tre's, steering rack... good luck
Old Feb 27, 2009 | 03:13 AM
JrAdrock's Avatar
New Member
Default Check this link out......
It is on an S4, but it's the same on an a4. It shows you what to look for on the top, but remember that the same can occur on the two bottom arms as well. So do the same wiggle test while looking at the lowers as well.
Check your tie rod ends as well. Even if the boots are not torn, it doesn't mean the ball joints are bad.<ul><li><a href="http://www.youtube.com/watch?v=tbeBvu49ts4">http://www.youtube.com/watch?v=tbeBvu49ts4</a</li></ul>
mchang
13
Mar 28, 2009 09:13 PM
ex-a8drifter
Mar 3, 2005 03:42 AM
4000skq
Nov 7, 2003 08:34 AM
aspire a4
Oct 5, 2001 07:18 AM
Ivan
Feb 28, 2000 06:29 AM
