Help. Front left brake pad squeals/chirps when steering is neutral...
...got Mintex Red pads on there with a few thousand miles on them (including one track event where I abused the snot out of them). Front left pad is making me nuts - it squeals when the steering is neutral...moving the wheel left or right will stop it because the pad touches the rotor.
Is there a home remedy to my problem?
Remove pads and clean them and any contact points. Use any of the available brake pad noise
suppresion compounds( I like the grease types)and apply it to any metal to metal contact point between the backing plate and the caliper/carrier assy. You can also put a slight bevel on the edge of the pads ( this sometimes helps.)
