HELP! I Need Window Regulator Clips
I am trying to find the little plastic clips that attach the door window glass to the cable on the window regulator. I would be happy to buy somebody's old (even broken) window regulator, if the clips are good. I'm getting pretty desperate here, I don't want to shell out over $100 for a whole new regulator just to get those stupid plastic clips! Can anybody help me out? Email me at CEEANTON at BELLSOUTH dot NET
Thanks!!!!!
Thanks!!!!!
Former Vendor
Well..
I have an extra brand new window regulator. BUT I removed 1 green plastic clip from it.
If you have a picture of the clip you need, I'll check. Perhaps you two could split up the regulator.
Re: Well..
ooo, ooo, that will work! I can re-use one of the clips I have. The other is broken into multiple and missing pieces. So, I can really get away with acquiring one. What do you want for the lone clip?
Anthony
P.S. I don't have a picture of it, but I can get one if necessary. I doubt the clips are any different, though. I have a 97 A4 2.8 Quattro. The clips are probably the same (or close enough that I can MAKE 'em work), even across model years. The part itself is kind of a lime green with a slot for the metal window bracket to slide in horizontally and a slot for the cable to slide in vertically.
Anthony
Former Vendor
Missing clip
The regulator I have is the driver's side.
Here's a picture of a similar regulator. The piece that's missing from my extra one is circled.
<img src="http://pictureposter.audiworld.com/13830/windowregulator.jpg">
Re: Missing clip
I am assuming that the driver's side and passenger's side clips are the same, although I haven't compared them. I can't really tell from the picture if the front and rear clips are the same. I will check my clips at home tonight and see which one I have and which one is broken.
Re: Missing clip
Okay, maybe I do need both. I can't get a really clear view on the picture, but it looks like there might be a little piece missing from the one clip I have. Sigh. Wel, anyway, how much do you want for the one? I can beg, borrow or steal to get the other one.
Re: HELP! I Need Window Regulator Clips
Does anyone else have an regulator lying around (even an old broken one) that they might be able to spare the clips from?
Thanks!
Anthony
1997 Audi A4 2.8 Quattro
Thanks!
Anthony
PuRe
06-26-2006 06:00 AM
teabagger
05-29-2004 12:41 PM
