HELP me please.....
Old Nov 17, 2002 | 06:54 AM
Niko_F's Avatar
Default HELP me please.....
ok herres the situation, i was driving on the highway at about 75 or so when i heard a loud shreeking sound then it almost felt like i had a flat, i pulled over...nothing so i got back in kept drivng thne my car had no power after like 3000 rpms it would jut kick and id have to change gear whatever it is came from the passeneger side because the person that was sitting there felt something near her feet she said i looked under the car noting...what happened? anyone have any ideas? please help me
Old Nov 17, 2002 | 07:06 AM
OneEighth's Avatar
Elder Member
blown turbo?
Old Nov 17, 2002 | 07:09 AM
Niko_F's Avatar
Default Re: blown turbo?
thats what i was thinking, but i dont hvae a boost gauge how do i check
Old Nov 17, 2002 | 07:10 AM
maggio's Avatar
what do you mean "it would jut kick", please ellaborate.
Old Nov 17, 2002 | 07:13 AM
Niko_F's Avatar
Default Re: what do you mean "it would jut kick", please ellaborate.
like after around 3000 rpms if i press the gas the car literally kicks and it wouldnt increase in speed till i changed to a higher gear
Old Nov 17, 2002 | 08:11 AM
WYSIWYG's Avatar
Default if the rpm needle is super slow and at a consistent rate then its probably the turbo
if it dies out at some rpm then it might be electrical/ignition
Old Nov 17, 2002 | 08:13 AM
WYSIWYG's Avatar
i would also think the *ticking* maybe coming from a collapsed cat conv guts
Old Nov 17, 2002 | 09:20 AM
maggio's Avatar
Default maybe limp mode...i had a blown turbo and...
the only downside was the car was veeeeeeeeeeeeeeeeeeeeeeeeerrrrrrrrrrrrrryyyyyyyyy slow. no other symptoms than that. i eventually k04'd. hope this helps.
Old Nov 17, 2002 | 09:50 AM
fastdream's Avatar
Junior Member
Default another easy possibility
sounds like it could be a bad plug wire. Except for the events leading up to the problem (shreeking, feels like a flat) the kicking symptom is very similar to what happened to my GTi. I had one of my cables (new ones too) broken and arcing against the head, causing bucking under acceleration, especially at higher RPM. Though my problem also exhibited itself sometimes at lower rpm. It felt like it was "cutting out"
Shreiking to me usually sounds like a belt problem. That combined with a feeling of a flat tire sounds like it could be power steering type of problem...but that doesn't explain the engine problems. Maybe you lost a belt?
Guys, is there a belt that runs the power steering that would affect his engine as well?? Sorry for my ignorance. Just wanted to throw some more ideas out there.
Good luck, a good shop will figure it out.
ErnestoLeon
2.0T FSI Discussion
Feb 15, 2014 01:01 AM
ErnestoLeon
A4 (B7 Platform) Discussion
Sep 30, 2013 09:54 PM
LLRevolution
12v V6 Discussion
Nov 28, 2006 07:54 AM
AznSpik45
Performance and Tuning
Jun 23, 2004 09:31 PM
Brian@P.O.G.
9
Nov 26, 2001 07:08 AM
