lights, fan, wipers, turn signals not working
Old 10-16-2013, 03:13 PM
jamesjosephcolyar's Avatar
Default lights, fan, wipers, turn signals not working
wassup guys I gotta 98 a4 2.8 a couple of days ago my cars low beams, the fan for ac/heat stopped working along with the wipers. Anybody know of any fixes as in a relay or a ignition switch. All my fuses are good, no starting problem I just am clueless to what it could be. Any help would be great.
Old 10-16-2013, 10:04 PM
Tech Guru
4Driver4's Avatar
Ignition switch is most likely the issue. Second guess is x relay.
Old 10-21-2013, 02:32 AM
smee3041's Avatar
If its the ignition his switch check this out:-
https://www.audiworld.com/tech/elec91.shtml
This is a DIY replacement of the ignition switch with pictures.
The male part of the switch isn't expensive and readily available.
If its headlight related maybe checking relay 301 might be an idea and its very easy to get at. I found this on a popular online auction site :-AUDI A4 A6 FILAMENT MONITOR HEADLAMP LAMP CONTROL RELAY 301 4 A0 919 471
This also might help (its relay info) http://audi.humanspeakers.com/relays.htm
Good luck please let us know what solved your problems
Old 10-22-2013, 11:15 PM
twentysevenlitres's Avatar
Agree with ignition switch.
All those items share pin 75 on the ignition switch.
They don't otherwise all share a fuse or relay.
IntheQ5
Q5/SQ5 MKI (8R) Discussion
37
08-28-2023 11:37 PM
jeffkruse
12-16-2021 05:59 PM
stormchaser1967
09-02-2015 09:26 AM
Beena
A4 (B8 Platform) Discussion
09-02-2015 12:01 AM
Quick Reply: lights, fan, wipers, turn signals not working
