Help with Thermostat issues!!! New Member
I have an 01 A4 1.8T. The thermostat gauge sits at cold, intermittently, and I get heat out of the vents. I was thinking that it could be a sending unit or gauge. I would like to test the senors/sending units but dont know were they are at. Can anyone help me...Thanks.
Hope to be on here more
In another thread, I shared pictures since mine was the originial from a 98 A4 2.8. .now the temp sensor seems very accurate and moves right on up!
AutohausAZ has a good price on a new one.
http://www.autohausaz.com/search/pro...ender%20Switch
Some people mentioned getting a replacement clip, make sure you remove the old o-ring and replace it also.
It could also be your thermostat, you will still get warm air if it's stuck open. The heater should be HOT at normal temp, OEM thermostats tend to fail open, aftermarket fail closed.
If if it is the thermostat don't leave it too long as it will cause the car to run rich.
AudiWorld Expert
Here are the tech write ups for him on replacing the two sensors https://www.audiworld.com/tech/eng66.shtml
https://www.audiworld.com/tech/eng54.shtml
ado_dado83
05-02-2007 11:12 AM
TANGO- CACTUS NY
19
01-07-2005 06:11 AM
