Help!!!! undetermined boost problem......
Old Sep 23, 2002 | 12:19 PM
holychild666's Avatar
New Member
Default Help!!!! undetermined boost problem......
Well, I have a 1 bar Wett chip in my Audi A4 98.5 1.8TQ. I usually get pretty good boost. Then one day it just stop producing that high boost. So I took it to a shop and they took it apart practically looking for the problem. They checked the turbo, wastegate, DV, feul flow, cat converter, and everything looked fine. Now they suggested that it could be a programming failure. Could this be it? I mean does programming malfunctions happen? And if it does, what can i do to fix the problem of lack of boost? I also hear a low humming noise when I should be getting boost. The problem is that the 1st and 2nd gear doesn't produce the max boost it should (around 11psi) and doesn't hold. The other gears seem to hold the boost but there is still the lack of power. HELP!!!!
Old Sep 23, 2002 | 12:25 PM
New Member
Also, we checked it by VAC, said cat. conv. and O2 sensor failed or imcomplete
Old Sep 23, 2002 | 12:33 PM
mdwsta4â„¢uroslut's Avatar
Member
first gear will never produce full boost.
Old Sep 23, 2002 | 12:39 PM
New Member
But, I dont have my original boost....
Old Sep 23, 2002 | 01:53 PM
VicG's Avatar
Default That's normal after you clear ECU codes. Drive around for a while, they'll complete.
You can also do the item "tests" as outlined in the service manual to speed up the test completion. But they all should set to complete in about 20 minutes of driving (assuming nothing is wrong...)
Vic
JG27
2.7T V6 Discussion
Jun 15, 2017 02:24 AM
SolidFish
Rocky Mountain Discussion
Mar 1, 2008 06:55 AM
MCH 2.7t
Nov 10, 2006 11:46 AM
CO.Ultra4
Feb 12, 2005 05:24 AM
