Help on upgrading halogen bulbs
Old Jul 26, 2001 | 06:43 AM
AinsleyT's Avatar
New Member
Default Help on upgrading halogen bulbs
I burned out a bulb, so thought might as well buy a better one.
Right now, am choosing between Philips Bluevision or All Weather. According to the All Weather description on autolamps-online.com, having yellow light is better during bad weather conditions. Does that imply that Bluevision, since it replicates "white light", would be a poor choice in case of bad weather? One additional complication is how the fog light affects all of this.
Also, when replacing bulbs, do you have to replace all (low, high, parking, maybe fog lights??), or can you just replace the low (which is what burned out for me), since I hardly use the high beams anyway?
Any thoughts would be appreciated.
Old Jul 26, 2001 | 06:47 AM
spikeital's Avatar
You can replace the Low Beam seperate from everything else
Old Jul 26, 2001 | 06:48 AM
AinsleyT's Avatar
New Member
But Philips website does not advise that, or is it just a marketing ploy?
Old Jul 26, 2001 | 06:52 AM
spikeital's Avatar
Default Correction...
If you change the type of bulb in the low beam you must change the other low beam as well. You don't need to change the fog light bulbs.
Thanks,
Spikeital
Old Jul 26, 2001 | 06:56 AM
AinsleyT's Avatar
New Member
Default Excerpt from Philips website regarding this
To achieve the best possible effect it is recommended to convert the complete headlamp i.e. low & high beam plus parking light to BlueVision. Non BlueVision parking lights will appear dull and yellow when used in conjunction with BlueVision headlamps.
So does changing only the low beams make it look weird? Or is it just a preference issue?
http://www.eur.lighting.philips.com/press/automotive/bluevision.shtml
Old Jul 26, 2001 | 07:56 AM
nanotech's Avatar
Default Marketing ploy
<ul><li><a href="http://lighting.mbz.org/tech/info/bulbs/">Maybe this will clear things up a bit</a></li></ul>
ATH
Mar 15, 2004 02:42 PM
docmusolf
Jan 4, 2003 04:35 AM
superXracing
Sep 23, 2002 02:25 PM
uclaboy
Sep 10, 2001 02:58 PM
uclaboy
Aug 25, 2001 04:56 AM
