Holy Sh*t Fire fire fire A4 1.8t 99.5 54000 mile (relay 213)
Cleveland today realy cool snow strom WEEEEE (yes I have snows). I started to smell something then smoke Yes SMOKE. Holy **** I pulled across 3 lanes turned off the car the smoke went away in about 15 mins. I tried to start it. no problem like clock work car starts I sat there for 5 to 10 min no smoke nothing no smell but also no fogs, turn single, rear Defrost, or Ac/heat blower oh and one more thing no wipers. Oh the way home I am thinking relay,maybe main fuse ,maybe big problem. I get it home and start looking under the dash and there is some melted wire none bear you can see that thay have started to melt. I look closer and this relay with 213 is melted on the outside.I disconnected the battery. and started the work it was so bad when I tried to pull it out it came out in pieces pins still stuck in the in the shocket what a problem now. the pins came out and everything here is my problem what ever happen to blowing fuses frist. I tested the socket conntact with a Multimeter to see if there was any connection with zero Ohms.. Good none so where can I read the part number off this thing to replace it.
Avant Sport
12-12-2006 10:38 AM
