How do you wash your car when its cold outside??
I want to get rid of all the salt on my car and its around 35 today. This should be the highest temperature for a while. Should i just take it out and spray it down?
full detail before each winter. then just spray it down with the rinse at local self service carwash
too bad I missed the 60F days to do that detail
probably going to suck it up and then pull it into the garage with a heater.
Spring/Summer/Fall full details then I just keep my Adam's microdrying towel...
in the trunk for Winter spraydown(s) (only rinse) at DIY carwash. I then usually give it a little wipe down with Adam's deatil spray and microfibre when I get home or at lunch after the car has sat in the sun. I wish I had hit up the weather last week to detail for winter, but the sun goes down so early it makes it nearly impossible unless you do it on a weekend with work and all. The biggest key is proper and full details with 5 layers of wax before Winter arrives then it's just a matter of power rinsing your car
Did a full claybar and wax last weekend
Felt wonderful - so smooth. Then I parked near trees at work and the birds got to it. Argh...
As to the original question, when it's cold out, my brother washes it. He's good for something. Or it doesn't get washed at all. Remember, dirt protects the finish. ;-)
Consider a no-rinse wash...
Optimum No Rinse(ONR) or Quick and Easy Wash (QEW)are discussed at length at autopia.com. Search their formums for ONR or QEW.
I used ONR for the first time 2 weeks ago. Outside temps were 15F. I was able to wash my A6 and A4 with 3 gallons of water total. The stuff is very weird at first blush. There were no bubbles in the wash water. The polymers in the wash solution cause the dirt to adhere to the wash mitt ("sequester" is the word for it), so rinsing the mitt does not release the dirt into your wash water. I washed and dried a panel at a time as instructed. When I finished, I washed the mitt with soap/detergent and it released the dirt. Down the sink drain it went, my garage floor had a couple gallons of water on it and the cars were clean.
ONR is a worthwhile and useful product IMHO.<ul><li><a href="http://autopia.org/forum/">http://autopia.org/forum/</a</li></ul>
Normal wash for me
But also I live in Georgia so temps don't get to cold like up North its a high today of 55 which to me is freezing. But I do use warm water from inside for the soap and water.
heheh... not w/o a little suffering if you're in New England!
Rubber gloves are key - like the kind you wash dishes with - they keep your hands warm and shielded from the wind, and your sleeves from getting wet. Fill the wash bucket with hot water, too.
If you get a few hours in the afternoon sun and it's' not freezing, you can power through it. It's all about speed in the Winter. Get the whole car washed with the sponge, then do the rinse. Wash the weels and chamois the entire car dry. You may want to open the doors and dry the door seals and frame so this doesn't freeze shut
