How long does it take to fill your car with gas?
I'm just curious. Everyone asks me why it takes so long to fill my car up with a tank of gas. IIRC, the manual says you need to pump at a medium rate of speed because of the vapor lock system. I assume this is correct because everytime I pump gas, the nozzle will just shut off if I try to pump at a full rate of speed. I fill my car with 93 octane everytime I refuel so that isn't the problem. I sporadically overfill my tank with gas, as well because the nozzle wouldn't automatically shut-off when it's full.
Does this happen to anyone else or should I inform my dealer about this?
Mine is the same way depending on the pump and station, some I can go full blast others constantly..
shut off. I like the sunoco 94 pumps the best however, and what a difference over some other stations around here in CT.
AudiWorld Expert
depending on a fuel pump, it takes me 3-4 minutes to fill the tank on medium setting...
I have never overfilled the tank - I guess I'm lucky that the nozzles shut off in time.
AudiWorld Expert
10 minutes for a few gallons of gas is waaaay too long...
does it happen at just one particular gas station, or many?
If not many, just stay away from them.
If many, I would definitely take it to the dealer. Better yet, take your Service Manager for a ride with you to one of such gas stations and have him watch while you fill-up, if he dismisses your claims otherwise.
I've had no problems pumping full blast
From the day I got my car till now (almost 12k miles). Works just fine going full blast. Only shuts off when it's full.
