I'm guessing alignment.
Old Mar 20, 2008 | 02:45 AM
dieselfitter! 251's Avatar
Default I'm guessing alignment.
<center><img src="http://pictureposter.audiworld.com/115000/tyres.jpg"></center><p>Had a 'specialist' do the alignment about 6 months ago.... I'm getting 6K to a set of rear tyres...... GRRRRRR &gt;:O¦
If not geometery, any suggestions?
Old Mar 20, 2008 | 02:58 AM
4Rings::G2 boosted::'s Avatar
Banned
How low is your suspension? Depending on drop, this is pretty much normal.
Old Mar 20, 2008 | 03:02 AM
Greyhound Guy's Avatar
Default That is a bit much for the back. Do you rotate your wheels?
Certain tire models will increase inside wear as well. I had bad luck with potenzas and my car is stock sport.
Old Mar 20, 2008 | 03:03 AM
Standard quattro sport...6K? That's normal...c'mon, you must joking!
Old Mar 20, 2008 | 03:05 AM
Banned
Not normal for standard sport suspension. Def have your alignment checked.
Old Mar 20, 2008 | 03:06 AM
Default Nope, don't rotate, directional tyre.
So unless I was to rotate them with the front they stay where they're put.
Old Mar 20, 2008 | 03:09 AM
Default The cars currently in getting some work done....
..turns out there's a broken spring on the left rear, I'm sure this is a contributing factor tho not the only culprit.... I think I'll have to be paying a visit to Lomand Audi.
Old Mar 20, 2008 | 03:11 AM
Thats a reason why to avoid directional. But you can still rotate front to back.
Old Mar 20, 2008 | 03:17 AM
Yup, but this way I only have to change 2 tyres regularly....
Old Mar 20, 2008 | 07:14 AM
MikekiM@PureMS's Avatar
Former Vendor
Default What are your alignment numbers? Toe? Camber?
The mere fact they performed an alignment doesn't mean the numbers are any good.
