Important Coilover question!!!!..........
Old Nov 23, 2001 | 06:53 PM
mech IFR's Avatar
Default Important Coilover question!!!!..........
I am installing a set of koni coiloversright now, and i had a question. On the front suspension, where the spring (from the coilover) meets the movable ring (that ring that lets you adjust height), is there supposed to be rubber seat between the spring and movable ring? Does this rubber seat come from off of the stock equipment and on to tghe coilovers?
Pleas HELP, i am in the middle of this and NEED to finish. THANKS!!!!!!
-jim
Old Nov 23, 2001 | 07:02 PM
RKA's Avatar
RKA
AudiWorld Uber User
Default I'm not positive, but I believe on the front suspension, you will NOT re-use the rubber
spring seats. I have H&R's, and the spring sits right on the spring perch, which is directly over the spanners. I believe (not completely positive) that with Koni kit the spring rests right on the spanner.
Do yourself a favor, and set the spanner on the high side. It will be a lot easier to lower spanners, than it will be to raise them.
Old Nov 23, 2001 | 07:03 PM
BTCC A4's Avatar
Member
Default Here
<center><img src="http://pictureposter.audiworld.com/8257/dscf0477.jpg"></center><p>.. No
Old Nov 23, 2001 | 07:04 PM
Senior Member
Default You have mail...BTW RKA is right...but do it when you've attached the
top hat etc otherwise you'd have to compress the spring to put the top hat etc on.
Old Nov 23, 2001 | 07:05 PM
Senior Member
Saves the day!
Old Nov 23, 2001 | 08:27 PM
Dead's Avatar
Elder Member
No.
Old Nov 24, 2001 | 07:55 AM
JWG's Avatar
JWG
Member
No, but Koni does make an optional plastic washer that you can request for free.
shadyraven
17
Aug 19, 2004 08:14 AM
BSCA4
Nov 24, 2003 02:54 PM
lost in beer country
Apr 23, 2002 01:51 PM
allegro
9
Feb 21, 2002 11:49 AM
w00t
Dec 16, 2001 04:33 PM
