increasing keyless remote for POST 99.5 B5's.. I have searched and only found tips for pre 99.5
I put in new batteries assuming that to be the issue... no luck, still only works from about 10 feet or closer. Anything else that can be done to improve the range on a 2000...?? Thanks
Need to remove the C-pillar pass side and relocate the attenna there
The antenna is IN the C-pillar NOW or needs to be moved TO the C-pillar??
if it is not IN the c-pillar, where do I find it, and if it is in the C-pillar, where do I move it to?? thanks
I believe just relocate it a bit. ....
sorry, could not be more helpful since I never did the mod yet (traded the car before I could do it)
It's in the c-pillar, need to relocate it a bit
you have been quite helpfull, thank you, maybe locate in rear deck/shelf?? or c-pillar better??
And do you know how to remove the bolster (under c-pillar, once the seat is folded down) It seems it may be easier to remove bolster, grab the wire and pull it down, rather than try to get c-pillar off.
