installing corner lights
go to front right corner of engine bay (pick your favorite right)
find hole near fender tip on the radiator carrier, you will be using that hole to press down on a small plastic clip that is attached to the corner lamp. BEFORE DOING SO READ ON!
Use flashlight to find the white retaining clip that you will need to pull out in order to depress a plastic clip that actually retains the corner lamp.
Its VERY easy.
