Intermittent Boost Problem
While driving my boost will drop from the normal 11-12 down to 5 under WOT (GIAC chip). It normally happens at the lower RPMs (eg around 2000-2500). Once it happens it stays at 5 until the car is restarted and then it is back to full boost (I can even re-start the car while in motion and it is back to normal).
The front O2 sensor was replaced, the MAF was changed twice (once with a used off ebay - much worse, yellow engine light, the other was new and just put in two days ago - better, but it still happens).
Thoughts, suggestions? Thanks
It's less than $20 and should take less than 10 minutes to replace. I think ModifiedA4 did a write up on it.
