lean condition....HELP!
he cr ran good for some time and then cel.
so far i have a new MAF.3 days old.
also i have done 3 pressure tests and they all pass.i also fogged the lines and that passed.
the precat and post cat o2 are brand new
i replaced 90% of all the vac lines
any more ideas?i have a new fuel pressure regulator coming just in case.
i vaged the car block 32 is at +25 at part and +1.5 at idle
the maf reading is 3g/m at ideal
the car misfires under 14+ boost
i also hit soft limp mode.
any thing else i should look at?
current mods
giac chip
diverter valve upgrade
n75j
air intake (can this toss the reading off)(no k&n filter)
3' exhaust (new addition but the code came up before the install)
im going to change the fuel filter and run some cleaner though the engine. but what if i replace the fuel pressure regulator and the fuel filter and the condition is still there what do i do then?
at least its not misfiring just limp mode 10psi
how fast should the pressure fall when doing a pressure test at 18psi it took about 25 seconds to fall to zero with my finger over the pancake valve.i think their might be a small boost leak but i cant find it like i said and i fogged the lines and alot of the vac lines and pcv has been replace.
if i change the fuel filter and the code still comes up and no boost leaks what then injectors can a bad wastgate cause this i spike 20 and hold 18 untill it limps out 30 minutes later with a cel???
