Misfire problem - help!
Well according to my VAG tool I have a bad misfire on cylinder 1. On screen 15 I can see cylinder 1 misfiring nearly every revolution.
This is what I've done and nothing helped:
1) Swapped sparked plus with another cylinder
2) Swapped coil packs with anotehr cylinder
3) Check compression on all cylinders - ~120-130psi
4) Swapped fuel injectors with another cylinder
It still says Cylinder 1 is misfiring and it is running pretty rough. It is slightly firing because it runs even more rough when you disconnect the fuel injector electric.
4 days ago I had the same problem so i swapped the injects on cylinder 1 and 2 and the problem went away until today.
Does it sound like a bad wire feeding the injector or coil pack on cylinder 1?
Any way to tell from the VAG tool if the injectors are working correctly? How about if the coil packs are working correctly?
Thanks,
Chris
So are those just cooling fins for the amplifier? Now that I know it is that I'm pretty sure.
Thanks,
Chris
