multitronic
Old Oct 14, 2001 | 09:20 PM
EurôStyle's Avatar
Default multitronic
how does it work, do you shift like manual? or is it automatic?
Old Oct 14, 2001 | 09:35 PM
AndrewM (azdaspeed3)'s Avatar
Senior Member
Default its a continuously varaible transmission......
basically, its a system that uses pulleys to vary the relationship between engine and transmission. what that does is to continuously vary the effective gear ratio. what that means is that the engine is kept in the prime rev range for the load on the engine at all times. because it doesnt have a torque converter, it is more efficient than a conventional automatic. supposedly, most are a bit weird to get used to, but they are just as efficient as manuals.
as far as multitronic goes, it is audi's cvt. what the multitronic does is pre-select 6 "gear ratios" that it allows the driver to choose from in the same sense that tiptronic allowed you to choose from 5 actual gear ratios.
that good enough? its pretty general, but it sounds like thats what you wanted.
Old Oct 14, 2001 | 10:05 PM
EurôStyle's Avatar
Default Re: its a continuously varaible transmission......
thats dope, thanks, i gotta test one out my self.
GR8-LIFE
44
Dec 10, 2012 05:29 AM
gepetto143
Audi 100 / A6 (C4 Platform)
Dec 3, 2007 03:46 PM
zorro9999
TT (Mk2) Discussion
9
Jul 10, 2007 06:32 AM
GDawgA4
14
Sep 1, 2004 08:13 PM
