Need an A/C Compressor
Old Aug 1, 2005 | 07:25 AM
Phil Manro's Avatar
New Member
Default Need an A/C Compressor
It looks like the clutch has given up on my A/C compressor. In the past 2 weeks I have done the breaks, recharged the A/C (which will now need to be done again) replaced the coolant sensor and now the A/C compressor needs to be replaced. :-( I guess with 95K on the car, I should expect this. In the past 20K miles I have already replaced 4 of the 8 tie rods, all 4 wheel bearings, the timing belt/tensioner, and the water pump. $$$$$$$$$$$$$$$$
I have a '96 A4 2.8 if anyone knows where to get a good deal on a compressor (or a clutch kit?). A good working used unit would be great too.
Thanks,
Phil
Old Aug 1, 2005 | 07:32 AM
Nate (ETKA+Scumbag)'s Avatar
Keeper of the Cash
Tech Guru
www.car-part.com
Old Aug 1, 2005 | 07:41 AM
AudiMick's Avatar
Default The 96's can have two different compressors.
Before you just replace the compressor why don't see if there is 12V to the clutch when there should be. If there is 12V but the clutch is not engaging then its the clutch, but if you have intermittent 12V it could just be the relay.
Checkout the 12valve forum also. There are more people with 96's over there.<ul><li><a href="https://forums.audiworld.com/12v/pages/1.phtml">12v forum</a></li></ul>
Old Aug 1, 2005 | 07:49 AM
JAFO's Avatar
Default i don't see a clutch listed seperately but thet do have them for other models.
i'd take it to a shop to make sure what you need to replace as this ain't cheap.<ul><li><a href="http://www.blauparts.com/parts%20dept/climate%20control/e1/e1d/a4.shtml">http://www.blauparts.com/parts%20dept/climate%20control/e1/e1d/a4.shtml</a</li></ul>
Old Aug 1, 2005 | 07:59 AM
Phil Manro's Avatar
New Member
Default Re: i don't see a clutch listed seperately but thet do have them for other models.
Using car-prt.com (thanks GilliamOS) I have found several usd units for $100-$150. But the point about the relay is a good one.
Here is the VAG code:
1 Fault Found:
01270 - A/C Magnetic Clutch (N25)
36-10 - Open Circuit - Intermittent
Seeing how it is intermittent, I guess it may be worth it to try the relay 1st.
Any suggestions on where the relay is and how to get at it?
Thanks,
Phil
Old Aug 1, 2005 | 11:51 AM
JAFO's Avatar
relay would be my first move it'll be a lot cheaper. good luck
blink
Mar 5, 2019 06:26 AM
BFives
Apr 5, 2012 11:58 AM
wallaceno1
Jul 17, 2008 09:35 AM
|skolnick
Jun 24, 2007 02:03 PM
Object
Oct 20, 2001 08:37 PM
