Need Help ASAP - Transmission in Limp Mode - code P0717 input/turbine Speed Sensor
Transmission is in Limp Mode (PRND321 back-lighting has changed) - code P0717 input/turbine Speed Sensor Circuit No Signal
Car is shaking.
Is it Speed sensor? where is it located?
Any input please/what to do/where to check/replace?... im not close to home
Its Audi A4 99.5 2.8 AHA Quattro TIP
Car is shaking.
I was able to drive ~40miles by now, car is hesitates during acceleration and on low speed ~40mph and between 1300 to 2000 rpm. When I drive like more that 40mph car run fine. No cell for two days and no codes at all.
-I checked TCM just in case - everything is dry connectors look like new.
-tested “Crankshaft Position Sensor” with multimeter is shows 1070 ohm
I have 5HP19 Automatic Transmission Code DRN
Hello, there is already a solution for P071700 and more DTC, the repair is carried out in the tcu that has the gearbox on the rear side, you can disassemble and repair the same module for more info send me an email
Tufve (08-03-2023)
briansa4
08-12-2008 04:43 PM
