Need some help with identifying a noise/feeling
Hey guys let me start off with the problem. For about a month I started getting this noise/feeling from my front end when I turn. It is kind of like a "WaaauuWaaauuWaaauuu" Pulsing or surging noise, from the passenger side. I can also feel this pulsing a little in the steering and in the general car, but not much. But everything is quite and nice when the wheels are going straight. At first my father and I thought it was the wheel bearing in the front end.
After some searching on the forums, it seems like the wheel bearing noises go away when you turn, my develop when I turn. Then I saw some things about a CV Joint.
If anyone has experienced this or knows what I'm talking about it would be great to fill me in. The car is a 98 A4 TQM with 103k on it.
WB can get louder as you turn a certain direction, mine would grind excessivly when turned
my rear wheel bearing ground like that in a turn only. i replaced it and no more "wauuu wauuu"
Re: Need some help with identifying a noise/feeling
Ok cool, now I checked autozone to pick up some new fronts, I know a friend in a shop that does favors for me so he will install them or let me use his shop for a 24 pack =D. But was looking at advanced autoparts and they have two sizes? 75mm and an 82mm outer diameter? I looked at ECS and it seems 75mm is right, is this correct?
ehh order it from ecs... they give you new axle bolt and everything
and i can't remember but axle bolt are def year specific so i would go wih ecs not AZ... personal opinion... good luck
ZO BZ S4
02-10-2007 06:12 PM
daves4
13
04-23-2004 09:27 AM
20valvevermont
03-24-2002 04:23 PM
