Never ending Build in Chicago
I haven't posted here in a long time, so I wanted to share my build. There's a lot of things I'm doing with my A4.
I want to thank Issam from INA Engineering for all his help 1- Build a Stroker Engine 2 - Wideband Conversion - AEB to AWM 3 - Car face lift Stroker Build - So far what I have for my build ABA Forged Crank 82.5 Supertech Pistons IE Rods - I-Beam Precision 6057 Turbo PAG Logger Manifold 3in Downpipe 3" Custom Exhaust - (Doing some changes) 38mm MVS Tial External Wastegate ATP Fuel Rail Fuel Pressure Gauge 044 Fuel Pump Tial 50mm BOV RS4 Throttle Body 044 Fuel Pump ARP Head Studs Kit 058 ARP Main Studs 058 ARP Crank Bolt Crank Rear Seal Crank Gear Pulley ARP Fly Wheel Bolts Head Gasket set-(Big bore head gasket) Main Bearing Caps Billet Main Bearings w/Thrust Washer Set Rod Bearings +.001" ACL calico coated Fluidampr Harmonic Dampner Turbo Cover 1000cc Fuel Injectors Eurodyne Software Supertech Valves Cat Cam Springs Titanium Retainers Purple Cat Cams Lifters Timing Belt Kit All Mounts FX400 Clutch Light Weight Steel Flywheel Cat Cam Gear TR1035 - Treadstone FMIC with 2 1/2 custom piping 034 Motor Mounts 034 Trans Mounts 034 Snob Mount with Bracket JHM Drivetrain Stabilizer Apikol Rear End driveshaft JHM Solid linkage JHM Shifter Stabilizer B&M Short Shifter - with my own touch I also bought another parts, but it's a surprise until I get it Wideband Conversion - For the wideband conversion I bought all the wiring harness from a 01 AWM A4 - I currently started working on this I'll post more information on how everything goes with the conversion. Face lift - I painted my RS4 bumper Want to change the lower part of the rear bumper Want to change the sideskits I'm also painting my Boser Changed rear shocks and installing Neuspeed racing springs Changing to S4 brakes (front and rear) S4 front and rear seats Custom 3" exhaust Here's pics of my car before I put my car in the garage http://i94.photobucket.com/albums/l1...o/DSC01026.jpg http://i94.photobucket.com/albums/l1...o/DSC00955.jpg Here's how my conversion is going... Lol http://i94.photobucket.com/albums/l1...o/IMG_1301.jpg http://i94.photobucket.com/albums/l1...o/IMG_1304.jpg Here are some pics of the parts I bought http://i94.photobucket.com/albums/l1...o/DSC01181.jpg IE I-Beam Rods http://i94.photobucket.com/albums/l1...o/DSC01033.jpg Presicion 6057 http://i94.photobucket.com/albums/l109/un1ko/Me022.jpg When I got my block from the machine shop http://i94.photobucket.com/albums/l1...o/IMG_0633.jpg http://i94.photobucket.com/albums/l1...o/IMG_0632.jpg http://i94.photobucket.com/albums/l1...o/IMG_0579.jpg http://i94.photobucket.com/albums/l1...o/IMG_1107.jpg Thanks for checking out my post. More to come!!! |
Why do you have an 06A adjustable cam gear on the head if your running a 058 block?
Originally Posted by 600whpA4
(Post 24128639)
You mean the exacty same one BobQ sold to Rob which then had to buy a Autotech cam gear because he also owned a 058. He then tried to contact Bob about the issue and Bob would never answer or call him back. He ended up getting the Autotech cam hear from 034 which is the correct one.
The one on the bottom is what Rob got from Bob which is the 06A/06B cam gear, the top one is the he had to buy which is for the 058 block. Picture from Rob's face book page. http://a5.sphotos.ak.fbcdn.net/hphot..._3650277_n.jpg It's just BS that Bob wont even call me back. Thanks 034 for getting me the correct sprocket... http://www.034motorsport.com/engine-...e-p-20106.html Will fit all Mk4 and B5/B6 engines with 06A/B style motor. Looks like your going to have to buy a 2nd cam gear just like Rob did, good luck trying to get a hold of Bob seeing that he is pretty much blowing off everyone. |
(Post 24129345)
The one on the bottom is what Rob got from Bob which is the 06A/06B cam gear, the top one is the he had to buy which is for the 058 block. Picture from Rob's face book page. http://a5.sphotos.ak.fbcdn.net/hphot..._3650277_n.jpg The one you have is what 034 has on their site listed for the 06A/06B. http://www.034motorsport.com/engine-...e-p-20106.html Exactly why I asked, I do know a little about this stuff. lol Looks like your going to have to buy a 2nd cam gear just like Rob did, good luck trying to get a hold of Bob seeing that he is pretty much blowing off everyone. http://www.034motorsport.com/engine-...20v-p-795.html |
I have onlyl seen one 1.8t cam gear listed on the CAT cam web site.
AUDI CTVW006 1.8/1.8T waterpump(ext) (-2000) 4 cyl-20v Mot.AEB,ADR Odd thing is the link you posted is to 034's inline 5 turbo 20 valve engine page. You might just want to make sure you have the correct cam gear seeing that another 058 owner was giving the wrong one by Bob. |
(Post 24129906)
(Post 24129906)
CAT makes a camshaft gear that works with the 058 motor. Ruben measure the offset for me before you install it and I will tell you what model you have. |
yes Issam I know the 058 uses the same one, I have been runinng a Techtonics Tuning 16 valve cam gear on my A4 1.8t since 2003 :p
Just found it odd that 034 lists the 06A CAT cam gear and the Autotech 058 cam gear on their 1.8t engine page but not the 058 CAT cam gear. It's not likely 1.8t owners are going to look on the inline 5 engine page looking for parts. I just try to stay away from the CAT products as much as possible. lol Last thing I would want is for the OP to have the wrong cam gear and end up destroying all his hard work. |
Ok. So I installed the timing belt just to see if I would be off because of the CAT Cam Gear and it seems that I'm good to go. Everything lined up the way it suppose to.
http://i94.photobucket.com/albums/l1...o/IMG_1440.jpg http://i94.photobucket.com/albums/l1...o/IMG_1441.jpg http://i94.photobucket.com/albums/l1...o/IMG_1444.jpg http://i94.photobucket.com/albums/l1...o/IMG_1442.jpg I have a quick question and I was hoping someone can help me. I'm going to install this gear that connects to the IM shaft. Do I have to put grease? Are these the only 2 parts or am I missing something? http://i94.photobucket.com/albums/l1...o/IMG_1450.jpg http://i94.photobucket.com/albums/l1...o/IMG_1448.jpg |
You do know the Fluidamper is designed for the 06A that uses 1 belt to run or are you mounting a 2nd pulley on it like you have in one of your other pics?
http://i94.photobucket.com/albums/l1...o/IMG_1107.jpg Just wondering if that is the solution to running the Fluidamper on the 058. I know another 058 owner that put one on his car and ended up shifting some things around and modified a belt to make it work. |
