off the line...
1. slip the clutch too much when you start to take off
2. get too throttle happy and go too high in the rpms.
The stock clutch is not made to race and is too weak to hold anything above 4K on a launch.
Release clutch slowly so you ride the Clutch.
You need to heat up the Clutch as much as possible.
This will not wear you clutch as most of your driving is done in forward gear.
Once Clutch is heated up to optimum temp, you can tell this by a slight smell of burning Sugar, the immedialy slam it into first, floor accellerator so ecu is controlling engine by rpm limiter, the flick foot side ways off the clutch so clutch releases instantly.
By doing it this way you should have all the best crowd pleasing launch.
