Oil Change
any can post with pics on how to do an oil change for 1.8t 99.5. have the all equipment just want to make sure no mistakes will be made. heard a monkey could do the job but rather have some knowledge with pics. thanks in advance. i know this is a big request but i am sure you will be helping out dozens and dozens of people.
anybody else not surprised this was posted by somebody w/ the handle "AudiTech"?
sorry, can't help w/ the pics, but it is pretty damn easy. The only "trick" would be that is is easier to access the oil filter by unsrewing the coolant tank (3 or 4 phillips head screws) so you can push it to the side.
1) search in the "Tech" library 2) STFA
What do you need pictures for? Can't understand English? A simple procedure should be sufficient
- remove undertray - drain oil - remove filter - install new filter - install undertray - add oil |
