oil leaking from intake?
<center><img src="http://modernhippy.com/images_external/intake%20leak.JPG"></center><p>Looks like oil leaking from my intake. do I just need to replace my injector o-rings or is there something else going on here (cause I didn't think oil could leak from here)
TIA
TIA
That's normal...that's the grease/oil the factory used to lube/instal the injectors
The oil/grease over time expands and seeps all over the intake, making it look like u have an oil.
I have seen it on other 1.8t engine (not the AEB)
Re: Are you sure it is oil and not fuel?
I'm not positive no, but it doesn't smell like gas. I would think gas would clean that area more than it would stain it black. It also looks like oil is leaking from the bottom of my charge air cooler, though that shouldn't be possible either. Is it possible to get oil trapped in the air system?
Re: this could explain alot
I did a search for "crank case breather hose" and saw what you were talking about. I think this could explain it. I'll put it up on ramps tomorrow and check..
thanks man!
thanks man!
