ok...car is not starting...its the battery...opinions..
i just got back from a trip overseas, so the car hasnt been started for 3 weeks. it had enough juice to barely start once.
after a 15 minutes drive i tried to start the car again...it wouldnt really turn over.
the voltage meter when the car is "on" reads 9 volts.
i jumped it and its now idling...
how long should i idle to charge the battery? (or should i even do that?) thanks!
i was thinking of getting a new one anyway since the car is 5 years old, and on the original battery.
Re: ok...car is not starting...its the battery...opinions..
Idling to recharge if the battery is completly dead is not a good way to recharge the battery. The best thing you can do is put a trinkle charger on it and let it sit at least over night...12-24 hours would be better. If the battery is 5 years old and has been discharged a few times it maybe junk and not take a charge time for a replacement. I like Interstate and have heard good things about Sears Diehard gold.
well it idled for 30mins...it looks like it worked (for now) the voaltage reading while off is...
just under 14volts...ill check it again in awhile to see if the charge holds.
bertworks(dan@jhm)
11-06-2006 05:41 PM
Asicks2.7T
02-01-2006 06:05 AM
audiringpwr
01-13-2004 09:38 AM
