Overhiting...
Old 01-12-2005, 11:32 AM
New Member
QuattroDrive's Avatar
Default Overhiting...
I have a problem with my A4, when car is cold verything is OK but as soon it gets hot it starts loseing power could it be possible that my water pump is f*** up or what is the deal, I finaly passed emmision test after replacing ECM and that random missfiring is gone but I steel have this overhiting problem, while I was in Europe my car has been siting in my garage for like 2 years maybe I just need a cooling flush or something?
if anybody knows or if you had the same problem pls respond
Thank YOu!!!
Old 01-12-2005, 11:46 AM
Member
Yippers®'s Avatar
Check the coolant temperature sensor
Old 01-12-2005, 12:10 PM
New Member
Default Re: Check the coolant temperature sensor
But I can see water boiling...
Old 01-12-2005, 12:13 PM
New Member
VAG is reading temp ok it goes from 80 to 120
Old 01-12-2005, 12:15 PM
RKA
AudiWorld Uber User
RKA's Avatar
Change the thermostat.
Old 01-12-2005, 12:17 PM
New Member
Default You think my water pump is OK???
I hope 'cause I 've heard that is a bithc to replace it...
Old 01-12-2005, 12:20 PM
New Member
Default And it has too much pressure on the coolant cap
if I leave 't open all water is gonna go out, it feels like water is not circulating at all...
Old 01-12-2005, 12:23 PM
RKA
AudiWorld Uber User
RKA's Avatar
Default It's probably fine....
How old is the car, what engine, and how many miles?
You may be due for a timing belt change soon, and if you are, I would recommend you do the timing belt, water pump, and thermostat all at once. For now, you really need to address the overheating issue. A thermostat is a cheap part, and easy enough to change on it's own. If that doesn't solve the issue, then the next step will be the waterpump...but as I said, at that point, you will probably want to consider spending extra money and doing the timing belt work with it.
Old 01-12-2005, 12:25 PM
RKA
AudiWorld Uber User
RKA's Avatar
Default You're supposed to have pressure there...
The reason the pressure is getting too high is because the coolant is getting too hot. Pressure is proportional to temperature.
Old 01-12-2005, 12:26 PM
Member
Yippers®'s Avatar
Default Completely missed that overhiting=overheating
I thought he ment it fell on it's face once it was up to temperature .. doh!
Quick Reply: Overhiting...
