Part number of shifter washer??
Can someone with a parts CD find the part number for the large aluminum rectangle washer that is used to connect the shifter linkage to the transmission selector rod? I lost mine during my V&S ss install.
oh yeah 1998.5 A4 1.8T quattro manual. |
thats a pretty big washer to lose. lol....where did you drop it.
into the drive shaft area?
I think I dropped into into the drive train tunnel. It did not fall onto the ground. I removed the entire center console so its not under there. I guess it sitting somewhere on top of the transmission.
the only three places it can be....
in the shifter housing, in the boot that leads from the housing to the transmission, or the ground...
I dropped my torx bit into there the other day... lol.
there is a 4th,
Items can also get into the center console, which I have checked. It slipped out of my hand near the rear of the shifter housing, so that kind of eminated the boot. On the way to the ground I think it has been blocked by a heat shield.
My torx bit went back underneath where the e-brake and cupholder are...
I'm going to need to pull that piece to find it, correct?
Re: My torx bit went back underneath where the e-brake and cupholder are...
thats what it sound like to me. There is a good write up in the tech article about how to remove the center console.
Re:
Yup, I'm familiar with most of the writeups. Just not wanting to pull everything out.
893-711-237-B
there are 11 in the USA, all of them in NJ.
