Please diagnose problem
Now, however, when I start the car, the steering goes kind of tight, there is a weird noise coming from the driver side of the engine area and I can feel pretty strong vibrations through the steering wheel, especially when turning. Also feels a bit like I'm driving with the parking brake on. This all goes away after about 15 minutes. Any idea what this could be? Does the OIL servive indicator mean anything other than it's time for an oil service?
Thanks.
And I winder what else they did not check for your $19.95.
Do you have bad TRE's? Torn CV boots? Leaking rear diff?
You do not know, because the $3.35 per hour guys you use do not check it.
I doubt they use an Audi filter...
Check your steering fluid first, if low go to an Audi or VW dealer, buy a can and top it off.
If the fluid level is OK, the pump may be binding, and/or the system may need flushing.
No Pep Boys there go to a Dealer.
