please help! Having trouble finding the solution
Old Apr 4, 2006 | 11:50 AM
pianogrg3's Avatar
New Member
Default please help! Having trouble finding the solution
edit delete
On my 97 A4 2.5 I was driving down the highway and all of the sudden I noticed my whole instrument cluster guages went to zero. The car was still running fine, and I got off the exit and stopped to try to restart it and reset it maybe, but the car was dead. It woudln't start. About 3 minutes later it started, the gauges were working fine. Everything was 100% power. Its like I was losing power everywhere, and my gas was working fine untill I got off the highway and then it was like feeling like it was going to stall after first gear. This is the second time it has happend. The last time it was like 6 months ago or so. The battery is pretty new. And there are no warning lights on. Any help would be awesome!
Old Apr 4, 2006 | 11:57 AM
WJM's Avatar
WJM
Tech Guru
Default sounds like a loose ground/earth connection....
you should check all the attachments (usually along the firewall)
Old Apr 4, 2006 | 12:10 PM
pianogrg3's Avatar
New Member
Default Re: sounds like a loose ground/earth connection....
so what exactly am I looking for? What kind of connection would it be?
Old Apr 4, 2006 | 12:54 PM
WJM's Avatar
WJM
Tech Guru
Default a bolt with a wire connector and a nut...
the nut maybe loose allowing the cable to move on the bolt, or there maybe severe rust/oxidation that needs to get cleaned up
Jaytirso
Audi allroad
13
Aug 2, 2015 04:03 PM
Snowcar84
Apr 4, 2008 12:35 AM
pianogrg3
Apr 3, 2006 02:06 PM
koopS2
10
Oct 8, 2005 07:02 PM
Distinct
Jul 30, 2005 02:28 PM
