Please help.....rattling sound in the engine bay while idling/running...
Old 04-03-2001, 09:14 AM
Junior Member
Vince L.'s Avatar
Default Please help.....rattling sound in the engine bay while idling/running...
Could it be my engine support needing to be replaced? I was trying to look for the source but cannot seem to determine where. The sound is pretty much comes from the deep side of the engine bay by the intercooler. The rattling has a constant sound (like continuous marbles rolling) regardless of RPM range.
I think its the engine support as the sound disappears upon sudden jerks of the car/engine when reversing or hard braking. Please give advice. TIA!
Old 04-03-2001, 09:18 AM
Senior Member
Dave Griswold's Avatar
Default I had a similar sounding problem, but only under 3500 RPM...
Turned out my timing belt tensioner had crapped out and the timing belt skipped a tooth.
Car sounded like a diesel. At first I thought a dust shield was WAY loose, but not so.
Don't know what your experiencing. Good luck.
Old 04-03-2001, 09:21 AM
Junior Member
Vince L.'s Avatar
Default If it wasn't under warranty, how much would you have spent?
Damn dealer might say its because of my lowered suspension. They might use this to skip having to shoulder the warratny.
Old 04-03-2001, 09:26 AM
AudiWorld Expert
Mr. Mom's Avatar
Default does it go away if you depress the clutch?
if so, you need a new throwout bearing.
HTH,
Peter
Old 04-03-2001, 10:08 AM
Junior Member
Vince L.'s Avatar
No it doesn't.
Old 04-03-2001, 10:21 AM
Senior Member
Default It was under warranty, but I switched my stock chip back in...
I honestly don't know how much, but I think it was 2 or 3 hours of labor...going from memory, so I'm not very accurate. Sorry.
AudiS4inCT
09-18-2010 02:50 PM
Thepooj
14
08-19-2008 07:30 AM
u7401087
11-20-2006 05:32 PM
Hawaiian sTTyle
02-24-2005 05:48 AM
samjogo
06-08-2002 05:13 PM
Quick Reply: Please help.....rattling sound in the engine bay while idling/running...
