Please help ... running rough, pulled codes
Old Apr 23, 2009 | 07:43 AM
RS4Andy's Avatar
Default Please help ... running rough, pulled codes
I already did a search and had no luck. The car just started running rough and wants to stall, it feels like it is missfiring or running on 2 or 3 cylinders.
Can someone please elaborate or help explain these codes? Could it be the coil packs?? Or bad gas??
Thank you.
Oh, it's a b5 1.8T 5 speed quattro
7 Faults Found:
17939 - Camshaft Timing Adjustment: Open Circuit
P1531 - 35-10 - - - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 - -
16685 - Cylinder 1: Misfire Detected
P0301 - 35-00 - -
Old Apr 23, 2009 | 07:48 AM
myers1.8TQ's Avatar
I was lost, now I'm found
Clear codes, go for a drive and scan again.
Old Apr 23, 2009 | 07:59 AM
RS4Andy's Avatar
Hi Chris,
I just cleared the codes, went for a drive and now I got this:
3 Faults Found:
18619 - Bank 1; System too Lean at Idle
P2187 - 001 - Upper Limit Exceeded - Intermittent
18621 - Bank 2; System too Lean at Idle
P2189 - 001 - Upper Limit Exceeded - Intermittent
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 001 - Upper Limit Exceeded - MIL ON
Old Apr 23, 2009 | 12:02 PM
RS4Andy's Avatar
Thanks for all the help everyone. New plugs and coilpacks and she's running like new with no codes.
Thanks again!
Old Jun 15, 2010 | 01:55 PM
ykrainskiy_boy's Avatar
Default Please help
It looks like I have similar problem. It feels like one of the cylinders doesn't work.
Here are the codes i get:
08583 Bank 1; system to lean at idle P2187
01287 Idle control system RPM higher than expected P0507
08825 Leak in air intake system P2279
Any one have a clue whats wrong with it?
Thank
1 dott 8
NY / NJ / CT Discussion
Apr 21, 2008 04:31 AM
EuropaA4Quattro
1.8T Discussion
Jul 3, 2007 08:42 AM
EuropaA4Quattro
Apr 19, 2007 02:42 PM
I AM 2ks4
Nov 19, 2004 01:27 PM
D all over
Jun 8, 2003 01:04 PM
