AudiWorld Forums
AudiWorld Forums (https://www.audiworld.com/forums/)
-   A4 (B5 Platform) Discussion (https://www.audiworld.com/forums/a4-b5-platform-discussion-1/)
-   -   POLL: post your Operating oil temp casual; Oil temp spirited; Oil type; Engine size; Chipped (Y/N).. (https://www.audiworld.com/forums/a4-b5-platform-discussion-1/poll-post-your-operating-oil-temp-casual%3B-oil-temp-spirited%3B-oil-type%3B-engine-size%3B-chipped-y-n-130908/)
ex-quattro PETE 01-10-2002 07:58 AM
also, what ambient outside temperature does your response refer to? If cold weather and warm weather results are much different, please post both.
Kris Hansen 01-10-2002 08:37 AM
That's kind of a hard thing to poll aobut. If you are worried about your temps,
As long as they don't exceed 250 REGULARLY, you are fine. IF you get over 250 alot, go to a higher viscosity of oil. It is normal for the temps to vary considerably depending on load, outside temps, etc..
ex-quattro PETE 01-10-2002 08:50 AM
nah, I just wanted some statistics to crunch...
my case is actually the opposite. I practically don't reach 200F at all. Is running in the 175-200 range bad for the engine, even if I push it hard?
Kris Hansen 01-10-2002 08:53 AM
The only thing you want to look out for is condensation in the oil.
My wife is great at taking short hops, the car never warms up at all. THe inside of her valve covers, vent lines, filler cap etc are coated with this lovely white froth. It can clog your vent lines, and is very ugly.
If the oil never gets up to temps to burn off the moisture that is naturally there, you can get problems down the road.
ex-quattro PETE 01-10-2002 09:12 AM
Most of my trips are about 13 miles long (twice a day)....
and the temp gets above 175, but below 200, and stays there during the last 1/3 of the trip.
What is the minimum oil temp needed for the moisture you're talking about to burn off?
skabaru 01-10-2002 09:22 AM
I am almost always b/w 215-225....
BRK 01-10-2002 09:42 AM
200 / 215 / Mobil 1 0W30 / 1.8T / Y
Kris Hansen 01-10-2002 10:51 AM
IT should burn off if you stay over 180 for a few minutes.
You will know what I mean if you see it. Pop off your oil filler, if there is a white foamy goop on it, you need to get your oil temps up more.
Paul H. (near Annapolis, MD) 01-10-2002 11:24 AM
200 / 215-Winter 230-Summer / Mobil 1 10W-30 / 1.8T / Y
