possible V1 problem....
Old Jun 4, 2002 | 01:56 PM
BOOSTD's Avatar
Elder Member
Default possible V1 problem....
Lately I've been getting a LOT of false laser readings, always from the rear sensor...it happens all the time and never more than a half-second or so each time. I called V1 and basically the guy didn't know what it might be so to just send it in for repair or a new unit. Anyone ever have this problem?
Old Jun 4, 2002 | 01:58 PM
®ob's Avatar
Default Drive around a lot of Trailblazers?
I found their brake lights set of the laser
Old Jun 4, 2002 | 02:00 PM
BOOSTD's Avatar
Elder Member
Default that's not it...
every now and then I get behind a Trailblazer or Avalanche (among other GMs) which will set it off, but this will occur at any time even with no other cars around. And as mentioned it's ALWAYS pointing backwards, never from the front like it does if it picks up an LED 3rd brake light.
Old Jun 4, 2002 | 02:33 PM
James R.'s Avatar
Default Hrmmm...well some road reflectors will shine red back at you
from traffic going towards them, but I doubt this is it. It also mentions in the V1 manual that some things like Neon lights and signs and set it off. You'll notice that Audi's own interior lights will set it off if you point either end towards the radio.
Please try the following...put some black electrical tape over the sensors. This will eliminate your laser warnings...but will NOT impair your microwave range...if you still have false readings something is wrong with the V1 for sure, though the the sensor could go bad in a funky way causing it to be receptive to light that's out of band...but IIRC the reddish tint of the plastic on the V1 acts as an optical low pass filter...so whatever is doing it it's IR or Laser (in the IR range...below where visible red occurs)
Anyhow try the tape...see what you can find out.
Regards,
Old Jun 4, 2002 | 02:46 PM
skabaru's Avatar
Default well, how is it wired?
I had laser falses before I had it hardwired...
Old Jun 4, 2002 | 03:06 PM
BOOSTD's Avatar
Elder Member
mine is hardwired.
Old Jun 4, 2002 | 04:18 PM
EdP's Avatar
EdP
AudiWorld Uber User
Default Not a problem...
Probably a Lincoln navigator going the other way and hitting their brakes. Those cars use a plasma/neon third brakelight that drives laser detectors absolutely NUTZ. There is a tech article on V1's website about red neon, and the particular cars that emit the right freq of light.
Old Jun 4, 2002 | 04:46 PM
BOOSTD's Avatar
Elder Member
Default incorrect...
this can happen with NO other cars around...it's random and happens 10+ times between home and work (2 miles), and before this week it never occurred.
Old Jun 4, 2002 | 05:21 PM
EdP's Avatar
EdP
AudiWorld Uber User
Default well maybe....
you're driving it as nutz as you drive us.
:P
Minimization
May 16, 2003 04:32 PM
capitolm94
10
Oct 7, 2002 11:53 AM
S4_Obsessed
9
Feb 28, 2002 05:45 AM
S4Del
10
Dec 6, 2001 03:20 PM
o2bnme
10
Oct 18, 2001 04:00 PM
