problems with GIAC
Old Jul 21, 2004 | 09:09 PM
TurboB5 (Cory)'s Avatar
New Member
Default problems with GIAC
i got a GIAC chip and i dont feel much extra power that everyone says they get...where should i check to see whats wrong...what are possible problems...a boost leak..anything else could happen?
Old Jul 21, 2004 | 09:10 PM
paul_858's Avatar
AudiWorld Expert
flash? or solder/socket?
Old Jul 21, 2004 | 09:15 PM
New Member
Default Acutally. i bought a chipped ecu...its soldered in there...
i have a stock ecu and then i have a chipped ecu i just bought it because it would be easier to deal with warranty problems.
Old Jul 21, 2004 | 09:17 PM
paul_858's Avatar
AudiWorld Expert
Default good choice, you can always take the ecu apart (4 torx) to make sure the chip is in there and that
it's not a stock eprom.
Old Jul 21, 2004 | 09:19 PM
New Member
Default I know its in there..
i took it to redline and it went all the way to 7100 and stock ecu it cant do that.. im wondering what is wrong and what should i do to fix it..
check to see if there is a leak...i also have a 710n Diverter Valve if that helps you.
Old Jul 21, 2004 | 09:24 PM
paul_858's Avatar
AudiWorld Expert
Default hard to say man, diagnosing cars on the internet is about as good as a doctor over the phone
check the vac-lines first and if you have access to a vag-com use that too.
Old Jul 21, 2004 | 09:26 PM
New Member
getting a boost gauge would def help right?
Old Jul 21, 2004 | 09:27 PM
Typist Formerly Known as (skene)'s Avatar
you sure you bought a chipped ECU?
Old Jul 21, 2004 | 09:28 PM
New Member
yes.im sure...has a different redline.
Old Jul 21, 2004 | 09:31 PM
paul_858's Avatar
AudiWorld Expert
yes
