Proper rear springs for 2000 1.8 ARG sedan
I bouht a car with damaged of one of rear springs. I replaced only one with similar. But now I want to replace both rear springs with identical new guys.
Cna you please tell me parameters for the springs or their ids, whatever?
Another question. I'll be replacing silent blocks ( https://encrypted-tbn0.gstatic.com/i...IOwCOpAt1NHJ2u
) along with springs. Maybe there is a reason to check smth around this area?
Part number is Audi 03115 for stock rear springs.
Here is a general guide:
https://www.audiworld.com/tech/wheel14.shtml
While you're down there in the wheel well, its a good idea to check for rust, especially in the area where the strut mount is bolted to the body (upper region).
After a visual inspection for obvious tears, you should also check the other bushings or silent blocks in the control arms using a crowbar or even a sturdy screw driver for excessive play. Here is such an example (skip to 12:00):
cabriolet rear springs (8G0 511 115a) are cabriolet specific springs fronts are same as B4 except 93
wisconsin_quat
15
09-05-2003 05:31 AM
Rhema
08-16-2000 08:29 PM
