Pulled the valve cover to replace chains....
Old May 18, 2008 | 06:29 PM
77'911's Avatar
Member
Default Pulled the valve cover to replace chains....
<center><img src="http://i27.tinypic.com/351y5qs.jpg"></center><p>I thought it looked pretty clean, no scoring at all on the cams. Here's the inside of the cover. Gasket is pretty hard though, it was time(already replaced at least once).
Old May 18, 2008 | 06:35 PM
77'911's Avatar
Member
Default Cams and head....
<center><img src="http://i27.tinypic.com/xp291y.jpg"></center><p>The lighting is bad, but it looked surprisingly clean.
qfrog Ti20's Avatar
Default Looks good.
Keep up whatever you've been doing.
Old May 18, 2008 | 06:40 PM
77'911's Avatar
Member
Default a comment....
Thanks. Let me tell you, it was a sigh of relief after looking at the rad and fan clutch. ; ) My guess is the family will get rid of it within the next year, but it looks good for 200k. The new chains should really put the timing on spec.
Old May 18, 2008 | 10:20 PM
Fremder's Avatar
New Member
Default very clean! ....
it's so cleaner than mine.. :}
I need to replace gaskets soon and it's gonna be my first work on mine.
One question!
do you just replace gaskets or do you use rtv?
Old May 19, 2008 | 03:02 AM
77'911's Avatar
Member
Default a response ....
Replace the gaskets.
Old May 19, 2008 | 11:54 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
were they worn? Why replace the chains only?
Old May 19, 2008 | 12:04 PM
77'911's Avatar
Member
Default a response....
Chains stretch, the car is at slightly over 90k, with a new w-pump &amp; t-belt, etc. going on the car, I'm hoping not to go in there for another 60k. They are showing there age. They don't line up to new spec alignment points, but at 90k, they won't. You think the tensioners should be replaced as well?
Old May 19, 2008 | 11:14 PM
Fremder's Avatar
New Member
so you don't recommend to put some rtv on the gaskets?
Old May 20, 2008 | 10:41 AM
freakness's Avatar
Member
Default rtv in the four corners is how everyone does it....
That helps to hold it in place while everything is torqued down.
sergeyk
Jan 29, 2009 10:04 AM
audispiff
Aug 6, 2007 08:32 AM
axecheerful
Jun 13, 2003 08:21 AM
lskolnick(original)
Oct 23, 2002 09:00 AM
