Radial Pull
Old Apr 18, 2002 | 04:40 AM
bpyewacket's Avatar
New Member
Default Radial Pull
Has anyone else experienced the effects of "radial pull" or "tire lead"? From what I can understand, a defect in the tire causes the car to pull one way or the other.
If you have, what did you do to get it resolved? I have a set of Toyo winter tires that developed this problem after only one season. I know for sure that it is the tire after triple-checking pressures, then eventually putting my summer set back on.
Thanks
Old Apr 18, 2002 | 05:34 AM
Yaz's Avatar
Yaz
Default if you do have the case of "radial pull",
tire rotations will change your symptom (stops pulling, or pulls to the other side). With few rotations, the tire shop should be able to tell you which tire is the culprit (if there is a defective tire with radial pull).
Audi Junkie
Wheels & Tires Discussion
Dec 13, 2008 09:16 PM
Tattoo
Pacific Northwest Discussion
9
Aug 15, 2008 09:20 AM
nemesisa6
NY / NJ / CT Discussion
Mar 22, 2008 07:38 AM
RA121125
May 13, 2004 02:39 PM
RobertG
Jul 31, 1999 04:51 PM
