radio problem, help needed
Old Jul 11, 2003 | 10:59 AM
reilly's Avatar
New Member
Default radio problem, help needed
Heard a crackling sound in speakers, next time I turned the car on, the radio didn't work. Here are the details:
- 99.5 A4 1.8T w/Concert system and self-installed panasonic 8D changer
- The concert panel turns on (Rand, FM2 buttons only) and lights up as normal. Even the backlight behind the digital display works....but the display doesn't show dgital words/numbers.
- Checked the CD changer. The ground had come loose. Reattached the ground, checked other changer connections.
- Suspected I had blown a fuse, but the radio fuse is ok
Any ideas? I appreciate your help.
Old Jul 11, 2003 | 12:00 PM
AudiForYou's 4.2's Avatar
Junior Member
Default There's a fuse on the back of the head unit. I'd check it. Will need Mercedes keys from Crutchfield
Grab the serial number of the back of the radio to get the unlock code through your dealer while you have it pulled out. Good luck.
Email me if you would like help. I'm in Boston and commute up 93.
isi0410
May 9, 2004 05:22 AM
reilly
Jul 11, 2003 12:19 PM
OwdyLover
Oct 22, 2001 09:01 AM
Jackson
Dec 10, 1999 09:25 PM
Denisboy
Mar 13, 1999 02:10 AM
