radio swap..
hey guys i got an odd question cause i know most people would just upgrade to an aftermarket radio. but i like the radios that are in the 99 a4's im wondering if anyone knows if they'd swap out easily from a 99 a4 to a 96 a4? just wondering any input or advice would be appreciated thanks. im wondering because my a4 doesnt have the 6cd changer
BTDT. It can be done but requires some re-wire. Search for a write-up on how to do this for the 95.5 urS.
1 Attachment(s)
Originally Posted by a4quattrojon
(Post 24105794)
A Concert I is a direct fit . However the new Concert I is set up via Audi K-line diagnostics and the original Delta doesn't have that feature. You need to splice in the K-line like the newer Audis. You need to cut the wire in the loom going to plug III pin 3 , then find the K-line wire going to the Climate control (IIRC it's violet / green on plug IA) and tap a new wire into it. Run the new wire to Plug III Pin3 . Install the concert I and use Vag.com to set the correct configuration. No of speakers, Bose etc. |
alright thanks for your help that dont seem like its to hard. will that radio fit in correctly too or am i gonna have to modify it for fitment?
1 Attachment(s)
hey, can someone clarify something for me?
I just installed a Concert I radio + cd-changer after removing my old Chorus I player (had volume issue) . Thing is the Concert was configured for BOSE system (i was getting BOSE on display when car start/player start). My cars PRCode: 8RN = eight speakers (active) but i only have 6 visible speakers on 4 channels. I used this configuration and it seems to work now : 00203 (front passive, rears active) . Using 5 (front passive, rears non-active) i could not use the FADE option. With the BOSE config i had no bass/lows in the car. How to tell witch one is best and whats speakers. |
(Post 24105846)
Coding info (use Vag.com) is here. http://www.ibiblio.org/tkan/audi/radios/concert.html |
Originally Posted by weaselciuy
(Post 24105932)
I just installed a Concert I radio + cd-changer after removing my old Chorus I player (had volume issue) . Thing is the Concert was configured for BOSE system (i was getting BOSE on display when car start/player start). My cars PRCode: 8RN = eight speakers (active) but i only have 6 visible speakers on 4 channels. I used this configuration and it seems to work now : 00203 (front passive, rears active) . Using 5 (front passive, rears non-active) i could not use the FADE option. With the BOSE config i had no bass/lows in the car. How to tell witch one is best and whats speakers. Speaker configuration will depend on whether your car uses an amp. Depending on the car wiring you are using either line -out or regular outputs. Line outs are on Plug I Regular speaker level outs are plug II Sounds like it's working as is. |
think maybe just aftermarket fellas
well i think im just gonna go after market that way its just plug and play, i want a flip up radio with dvd,cd and the navi system if possible anyone know any good radios like that? that will actually fit in our dashes? i was lookin on best buy but they say they dont fit our model cars? kinda gay i want one hardcore! with out having to modify and break **** on the dash lol! and i know our intakes are really good the way the are and i have heard of the whole darintake but id rather just get an actual CAI. anyone know any good manufacturers? Besides ebay i find them all over ebay with the MAF sensor adapter and all but for some reason i cant find any companies with a cold air intake system besides K&N air for the 2.8l 12v. anyone know anything appreciate it im sure its been discussed billions of times.
(Post 24106234)
There is no standard radio that fits that wide slot. CAI will make the car noisier but slower. |
I bought a 1997 a4 V6 that came with an aftermarket radio. The original wiring was missing, also there was no CD changer or its wiring.
I bought an oem Delta radio from ecs tunning and the metra adapter for this radio. When I installed the radio it didnt turn on. I send the unit and turned out its Ok, so I think I am missing something. Does the antenna need to be connected to lid the screen on? Does the CD changer need to be connected to lid the screen on? Any inputs will be appreciated Juan F |
