Random mis-fire HELP!!!
Old Dec 14, 2004 | 12:05 PM
Mutine bullfrog's Avatar
New Member
Default Random mis-fire HELP!!!
1996 A4Q 2.8 Manuel
I've had a check engine light come on and off for 2 years now. The code read miss-fire cylinder #1 then Random Multiple miss-fire.
I've tried every thing and my mechanical has given up. The car has plenty of power but runs a little rough. It idles at 750 (a little low). some times it takes a couple of cranks to get it started when cold. The spark plugs seam to indicate a slightly lean mix. And I get a slight knocking on heavy loads (up hill high gear). the car never stalls. I've changed the following:
Coil Pack, wires, plugs
Timing belt
O sensor
Fuel filter and pump.
Right side cylinder head (twice used)
Ignition module (used)
I did a quick check for a vacuum leaks on the top but found nothing. I know it sounds silly, but the light actually started coming on after I had the clutch and flywheel changed. Also the light won't come on if I run the car with the A/C on (raises idle).
The car has a S/S exhaust and K&N filter but light came on before they were installed.
Any Ideas, I'm dispirit
Old Dec 14, 2004 | 12:08 PM
kenny (dremel)'s Avatar
Default has your mechanic verified the timing's correct? ie, with a light?
Looks like you've covered your bases on replacing parts. Just throwing ideas out there.
qfrog@work's Avatar
Senior Member
Default UM.... codes?
what codes does it throw.
the CEL isnt just an ambiguous light... there are codes... you fix what is broken by what codes it throws.
Old Dec 14, 2004 | 12:20 PM
New Member
Default Re: UM.... codes?
This is exactly what comes out on the ticket. The 072 at the end of the code some times comes up as 93 or 92 and 120 (I have many tickets)
8D0906266B 2.8l V6/2V MPI OBD2 D01
Coding 01201 WSC 75100
16685 po301 072
Cyl.1
Misfire Detected
16686 po302 072
Cyl.2
Misfire Detected
16687 po303 072
Cyl.3
Misfire Detected
16684 po300 072
Random/Multiple Cylinder
Misfire Detected
Old Dec 14, 2004 | 12:23 PM
New Member
Default Re: has your mechanic verified the timing's correct? ie, with a light?
I wouldn't even know where to put the timing light on the car. Everything is set by the computer.
I have to believe the timing is OK because the timing belt has been re-installed numerous times. There is no other way to adjust the timing as far as I know.
Old Dec 14, 2004 | 12:45 PM
New Member
Also changed the fuel filters on the car
Old Dec 14, 2004 | 12:55 PM
Tom Serrago's Avatar
25 Year Member
Have the injectors and fuel pressure regulator been checked?
Old Dec 14, 2004 | 12:56 PM
qfrog@work's Avatar
Senior Member
Default good call... some of the V6 injectors did go bad...
and there was a recall on some V6 engines for the injectors.
Old Dec 14, 2004 | 01:00 PM
New Member
Default Re: Have the injectors and fuel pressure regulator been checked?
I've changed the injectors, but not the regulator. Wouldn't I loss power if it was a fuel problem?
Old Dec 14, 2004 | 01:09 PM
25 Year Member
Default Depends upon how bad the fuel pressure problem is.
The fact that you may be running a bit on the lean side may be an indication of a fuel system issue that is mostly apparent at low rpms.
Injectors that are dirty and missing will throw those same codes. Try a good dose of techron and a long high speed drive.
